Results 1 to 10 of 13
Thread: Three simple questions about TAF's and TFR's
    Three simple questions for the EAA forum readers:
    1) How often do you check a TAF before you fly?
    a) Never
    b) Only on long trips
    c) Every time
    d) Once in a while, it depends on my mood
    2) Rank your ability to decode a TAF
    a) I'm an expert
    b) I'm OK.
    c) I stumble through
    d) Right, what's a TAF?
    3) How often do you check TFR's before you fly?
    a) Never
    c) Every time
    d) Once in a while, it depends on whether someone important is coming to town
    steve's Avatar
    Utah
    c. every time
    c. stumble but my wx software translates the TAF into real words
    b. long trips but I get the email TFR notam
    St. Louis/Omaha
    C. A. C.
    And I make sure my students do it that way, too.
    ETA: I also make sure 1-800-WX-BRIEF is tattooed to the inside of their eyelids...
    Anxiety is nature's way of telling you that you've already goofed up.
    Green Goggles's Avatar
    Jan 2012
    Oklahoma
    A
    D
    A
    Ummm...
    Jan 2012
    C b c
    MickYoumans's Avatar
    KBXG - Georgia
    C
    b
    c
    steveinindy's Avatar
    Indiana
    1. Every time.
    2. Somewhere between "ok" and "expert"
    3. Every time.
    Amnegron's Avatar
    Jan 2012
    GA
    C
    A
    C
    Not too difficult
    c) Every time, though I confess that weather.com is my first check!
    a) I'm an expert (big stumbling block in training so I had to learn it through doggedness; now I can't unlearn it)
    I do mostly local area flying for fun, so it's take off and return!
    turbo's Avatar
    Sep 2011
    i check weathermeister.com before every flight. flying 300+ hrs a year, you want all the info you can get. this site gives it to you in 'plane' language. you can get a free month to check it out.
    Reported: April 24, 2012 at 7:20 AM
    Valid: April 24, 2012 at 8:00 AM - April 25, 2012 at 8:00 AM
    From 8:00 AM: Wind 300° at 6 kt, Visibility greater than 6 sm, Few 6000' (VFR)
    From 10:00 AM: Wind 330° at 10 gusting to 18 kt, Visibility greater than 6 sm, Clear (VFR)
    From 7:00 PM: Wind Variable at 3 kt, Visibility greater than 6 sm, Clear (VFR)
    From 8:00 AM: Wind 300° at 4 kt, Visibility greater than 6 sm, Clear (VFR)
    From 8:00 AM: Wind 310° at 7 kt, Visibility greater than 6 sm, Clear (VFR)
    From 10:00 AM: Wind 330° at 14 gusting to 20 kt, Visibility greater than 6 sm, Clear (VFR)
    From 8:00 PM: Wind 310° at 3 kt, Visibility greater than 6 sm, Clear (VFR)
    Reported: April 24, 2012 at 7:22 AM
    From 8:00 AM: Wind 330° at 10 kt, Visibility greater than 6 sm, Clear (VFR)
    From 10:00 AM: Wind 350° at 12 gusting to 18 kt, Visibility greater than 6 sm, Clear (VFR)
    From 7:00 PM: Wind 020° at 8 kt, Visibility greater than 6 sm, Clear (VFR)
    From 11:00 PM: Wind 350° at 3 kt, Visibility greater than 6 sm, Clear (VFR)
    Ed DArcy 'Turbo'
    R-44 N7511G 1,300 hrs / RV-6 N26ED 4,700 hrs / helicycle 100 hrs
    Stuart, FL Hartford,Ct Virgin Gorda, BVI
