Results 1 to 4 of 4
Thread: brake hose problem
    brake hose problem
    Have a master brake cylinder,has -4 AN 833 elbow, What do i need for a hose with a out put end that will match 1/8 pipe thread? Need numbers for hose,fittings. Thanks.
    steveinindy's Avatar
    Indiana
    Talk to the manufacturer as they probably have the information you are seeking.
    New Hampshire
    Actually, I believe that the info that you need can be found in the Aircraft Spruce catalog. It is a great refererence about parts and AN/MS part numbers for the novice.
    Quote Originally Posted by proplock View Post
    You want to attach a #4 hose to a 1/8"' NPT thread?
