Hi Guys and I really welcome this site it's about time that something like this was done for us homebuilders of all designsJ
The question I have to impose on someone who has the answer is this:
I am about to order a foam mock-up of an aircraft that sorta looks like the Velocity but is totally new in many of the features, this will be a once off copy once I finish I will pass on what I have learn including the moulds, it will be carbon-Kevlar and honeycomb and like the Velocity it will be lighter. Could I get into copyright infringement with Velocity if I proceed with this build or should I keep the dimensions and change the shape so it doesn’t look like their Canard?
I could really use some real honest input getting real close to making the order for the mock-up foam for the master mold.
Thank you for your input
