Results 1 to 4 of 4
Thread: Quest "Air Force"
    lnuss's Avatar
    Dec 2013
    Colorado
    Quest "Air Force"
    Ars Technica has a nice article about the "Air Force" of Quest Diagnostics, including some PC-12s, Barons and Embraer Phenom 100s.
    Larry N.
    Scooper's Avatar
    Jul 2016
    Santa Rosa, CA
    Quote Originally Posted by lnuss View Post
    The "PC-12" pictured in the article has the tail number N702QD which is not assigned according to the FAA registry. The registry says N702QD used to be assigned to a Socata TBM 700, but it was deregistered on May 2, 2017.
    The reason I looked it up is because the airplane identified as a PC-12 in the Ars Technica article is clearly a TBM, not a Pilatus PC-12.
    Aside from that obvious error, it's interesting that Quest Diagnostics needs its own air force to fly lab samples around the country.
    - Stan Cooper (K4DRD), Private Pilot ASEL, LSR-I, EAA 115792 Lifetime Member, EAA Chapter 124
    Experimental AMD CH601XLi-B, N601KE, KSTS
    May 2017
    Northern Alabama
    That’s not the Quest Air Force. This is the Quest Air Force. https://m.youtube.com/watch?v=DKhQg-GvynE
    LownSlow
    Scooper's Avatar
    Jul 2016
    Santa Rosa, CA
    Quote Originally Posted by Stolch View Post
