Results 11 to 20 of 21
Thread: Help with slat design
    The industry is disagreeing with you. Vortex generators are light, easy to install, and have a great bang for the buck. You see vortex generators on Super Cubs and Husky
    The best performing STOL aircraft are equipped with slats. I'm going to stick with my stance.
    The industry answer is that VG's are common and slats are not.
    I guess it depends on your definition of "the industry". There are plenty of designs marketed currently (the various designs of various Heintz STOL aircraft, etc) that have slats and they tend to be the best performers. Yeah, you're not going to cruise very fast but I keep getting told on here that the "average" GA pilot (at least by EAA Forums standards) are not looking to go fast and besides most STOL aircraft are limited by the LSA speed restrictions anyhow. The one major exception is really the Helio. It's the one "heavier" aircraft that I'm aware of with freakish STOL performance.
    Slats that are fixed force a full time performance penalty
    We're talking about an ultralight. The whole design of 99.99999% of ultralights is one huge performance penalty.
    and movable slats are more mechanically complex than you think.
    I highly doubt that since I just designed them for my turboprop and curse the decision to go with retractable slats. They are probably the most mechanically difficult system on the entire design and make retractable landing gear and the controls look like child's play.
    Max Torque's Avatar
    Quote Originally Posted by chacalextreme View Post
    Hi EAA fellows!
    I'm starting with a friend the design of an STOL ultralight. We would like to add a leading edge slat, and we are thinking in one that could be retracted to have a clean profile to increase cruise speed. This means that a regular profile should be modified to have slat and wing profile in his shape (we are thinking in NACA 4416)... Does any body knows some books that explains slat design? any start point to this endeavour? Any help will be highly appreciated.
    -Chacalextreme.
    Ultralight? Forego the slats, keep it simple and keep it light. Slats add weight. I would suggest a Riblett GA30A613.5 or GA30A615 airfoil for your application. If you absolutely must have slats, take a look at what Wayne Mackey uses on his SQ2.
    You might want to look at the latest design versionof the "Buttercup"...
    It has retractable leading edge slats and performs very well.
    Google "Luce Air" and communicate with Earl Luce
    Aug 2012
    England
    I hope you are still working on the slat idea. I have a few patents, now lapsed, that may interest you. You need to connect left and right slats. Asynchronous deployment is not good. You need to ensure slat trailing edge doesn't lift at high speed. I can't advise on profile. I think you would need some simulation.2D ok.
    Craig
    prasmussen's Avatar
    Feb 2012
    2OH8
    Is that a slat on the wingtip of a Culver Cadet? Someone said most rebuilders choose to eliminate that feature when they recover. Always wondered why.
    The journey is the reward.
    pylon500's Avatar
    Taree Airport (really) North NSW, Austrlia
    Technically, what's on a Cadet (and many like it) is a 'SLOT', which is built into the wing.
    Slats hang off the front of the wing and can be fixed or retractable.
    Not sure how many aircraft can close their slot(s).
    Some people opt to delete them on some builds, thinking that the weight saving would equal the effectiveness, Jury's out on that one...
    Arthur.
    The slot that you see on airplanes like a Cadet and a Swift are there so that as the airplane enters the stall, you still have some aileron control. Close the slots and the stall behavior of the airplanes get more "exciting". A very experienced pilot might think that is OK, a less experienced pilot might not. The slots add drag so the airplanes go faster with the slots closed.
    I will suggest that the average pilot will enjoy these airplanes more with the slots in their factory configuration.
    As for airplanes with slats like the Helio and the ME-109, the left and right are not interconnected and they pop out and move back in based on the airflow that speed and AOA present to them. If you get the chance to watch a Helio maneuver at minimum airspeed, watch the slats move in and out. The JAARS guys used to do a great demo at Sun-N-Fun. I have also heard anecdotaly that the ME-109 drivers had to avoid pulling too hard in a turn as they tried to get enough lead on their target to start shooting as the independent action of the left and right slats as the G and AOA loaded up moved the nose of the airplane around and upset their aiming. Someone else likely has more experience with that than I.
    Max Torque's Avatar
    Check out the Mackey SQ2 for a very effective and not overly complex LE slat design. The reports from the guys who have flown them are very good - superior performance.
    http://supercub.com/aircraft-catalog...eysq2info.html
    Satsuma, AL.
    I would guess that most light weight aircraft don't need the complication and weight of slats for their envelope of operations. The slats and other aerodynamic complications are necessary with higher weight aircraft like the Helio Courier.
    Many aircraft with normal operations and low horsepower can already land much shorter that they can take off and clear a 50' tree.
    The Cessna 150 comes readily to mind here.
    In the case of slats on the Zenith the Aussies have modified that bird and left off the slats and say that it performes better without them. Also they say that they do not act as part of the wing in that when removed the CG does not shift forward as expected when the distance to the leading edge is deleted. This indicated that the "area" added by that distance is not effective aerodynamically.
    Usually that part which is left off is lighter, cheaper, and more trouble free than those parts installed.
    Thomas Stute's Avatar
    Friedrichshafen, Germany
    What is the problem you want to solve with a slat? Is it for a friendlier stall behaviour or are you looking for an increase in CL in total? A good book to look at always is "Theory of Wing Sections" by Abbott and Doenhoff. You will find good expanations and a lot of airfoil data. It is purely engineering stuff but aircraft design is engineer's work.
    I don't agree that retractable or better "automatic" slats are complicated in design and building. There is no big mechanism behind it, just a low friction track and rollers, that's it. I have some experience about 20 years ago with the Morane-Saulnier MS 892 which had automatic slats. The high AoA behaviour of the plane was amazing. It was nearly not possible to stall the aircraft and with the stick fully aft you could land it like a parachute. It had excellent STOL characteristics and was easy to fly also for student pilots. And it was hard for students to make bad landings.
