Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 102
Thread: GA Turboprop
  1. #71
    I looked up a little on this Czech engine, TP-100, that Diemech Turbine Solutions will offer. It will be about $100k.. or probably a little more, like $125k. Does this price make this engine attractive as a piston substitute, or is it still too expensive?
  2. #72
    Auburntsts's Avatar
    Tampa, FL
    Quote Originally Posted by kjensen View Post
    Not in my book -- still costs too much. That engine costs twice as much as a brand new Lycoming IO-540 (fuel injected, 260-300HP, 6 cyl) and 3 times the cost of a good mid-time one.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
  3. #73
    steveinindy's Avatar
    Indiana
    Nope. Not in my book. Until it gets to be equal to or less than the cost of the piston alternative, it's not economically justifiable to replace a piston engine with a turbine engine that is of equal power.
    BTW, how's your paper coming along?
  4. #74
    Since it can only be installed in homebuilts, it won't get past the curiosity stage. I have doubts the engine can be certificated without doubling the current advertised price.
  5. #75
    Your "a little more" delta of $125k minus $100k = $25k is what a lot of us want to pay no more than for an engine, period. If you believe $25k is just "a little more," then you're living on a different plane of existence than most of us and this is the wrong place to look for favorable opinions.
    Bill
  6. #76
    Mike Switzer's Avatar
    Central Illinois
    While things may change by the time I get my plane ready for an engine, the engine I currently plan to use will cost between $10,000 - $15,000 max (supercharged aluminum small block Ford with all the options)
    All the bells & whistles, any US (normally aspirated) aluminum small block V8 will cost less than $10,000, a big block might hit $15,000 (these are numbers for aluminum blocks & heads, if you don't care about weight it will be cheaper)
    If you want to spend more money use a "real" aircraft engine, any turbine or diesel will cost more than that
  7. #77
    Indiana
    That was my thought too. If I'm shelling out $125K for an engine, that's not what I'm going for.
    Just out of curiosity what does one of the big blocks weigh? What's the difference in weight between the aluminum blocks and heads vs the other option (I'm assuming some form of steel)?
  8. #78
    Central Illinois
    I don't remember for a big block off the top of my head, I will try to look it up later when I have time - but for a Ford 302 the bare aluminum block is 90 - 110 lb depending on which one you buy, the cast iron block is around 200lb. Going of memory here, but I believe a 289 / 302 with aluminum block & heads comes in around 400lb - I am using 500lb for my preliminary W&B calculations to account for accessories, prop, etc.
    I know some of the cast iron big block engines came in around 700lb, aluminum block & heads would make them quite a bit lighter.
    Another thing to consider if you are looking at an auto engine, (I don't want to use a big block for both weight & space considerations) but as far as I have been able to find out the Chrysler Hemi (the original big block, not the new one) is the only engine that anyone is still making aluminum aftermarket dual plug heads for, which would allow a redundant ignition setup.
  9. #79
    Indiana
    Interesting. I would have thought it was a lot more than that but then again my only experience with one has been looking at it when it was in the front end of a vehicle.. Then again, I'm kind of weird in that I don't even change the oil in our car and have little interest in automotive mechanics, but I have a great desire to build an airplane. Go figure.....
  10. #80
    Quote Originally Posted by Bill View Post
    I agree with that, should have used different wording. I guess I said "a little" because that delta ($25k) is small compared to the delta between $100k and the price for a new P&W, GE, or RR engine.
