Originally Posted by
amtp1
Hi:
I was looking and could not find an answer to my question. I was looking at building a gyrocopter. The plans call for using 2" square tubing. They want you to drill 1/4" holes in the tube within .030 of the inside wall. I cannot see how you can deburr the hole properly on the side that is next to the wall. I have the tool that will work on the portion that is away from the wall, but I cannot see how to deburr next to the wall. It seems that you might damage the inside wall while trying to deburr this area. Any suggestions? Has anyone seen a video showing a possible solution to this deburring issue? Thank for your time and any suggestions in advance.
