Page 8 of 8 FirstFirst ... 678
Results 71 to 74 of 74
Thread: Marvel Mystery Oil?
  1. #71
    The A&P who did the annual on our old club Fly Baby started out as a mechanic on Northwest Airlines Constellations. He told me to use MMO on my Fly Baby's Continental to help forestall valve problems. And I have, for the past 30+ years.
    Oh, and it has kept the hangar clear of elephants, too.
    I posted a story of my old A&P to the Fly Baby web page:
    http://www.bowersflybaby.com/stories/legacy.html
    Quote Originally Posted by COMM114 View Post
    This much is true: MMO is not an approved additive for fuel or engine oil in any type of certificated aircraft engine. Period.
    Actually, Kinner service bulletin #130 recommends the application of Marvel-Oil as a valve stem lubricant to extend the life of valves guides.
    Best,
    HT & V
  3. #73
    Desert185's Avatar
    Feb 2019
    Nevada
    I added some to the crankcase of an old Dodge pickup in storage at another state. The engine would run, but not pull a load. I suspected lifter problems after troubleshooting the ignition system. After 20 minutes at a high idle, the truck ran like a top. The solvent will eventually burn off leaving only the engine oil. Normally, I don’t use it, but i always have some onhand for those times of need.
    I’ve also had a friend use it in an IO-520 with a noisy lifter. Cured the issue.
  4. #74
    Aaron Novak's Avatar
    Oshkosh, Wi
    Quote Originally Posted by high time cub View Post
    Best,
    HT & V
    Not only Kinner. Technical bulletins from American Cirrus and Continental ( for the A-40 ) suggest the same thing.
