that's not the first time you've mentioned the gear speed, Ron. are you bragging or complaining? either way, yes, you can fly the FISK arrival as stated. the NOTAM doesn't require gear down. page 4 says "If possible, lower your landing gear prior to reaching Fisk." you write your aircraft limitations make that not possible. so don't. leave it up, the optional part, and fly 90 kts, the required part. big deal. they'll get over it. just remember, for noise abatement, put it down before landing.
