I've been using Autolite 386 plugs and automotive wires for 11 years with my electronic ignition. It kills me to replace the plugs every year. Six dollars down the drain. ;-)
Kyle,
What engine are you using the Autolite 386 in?
Unfortunately, I spend a lot more for the plugs in my experimental O-290 than you do - comes out to about $20 for all eight plugs...
The Champion aircraft spark plugs I run in the engine in my Cessna cost about $26 each.
"You have to be alive to spend it..."
