Results 11 to 15 of 15
Thread: Restoring an Old A-65-8F
    Second thoughts
    If you elect to replace the engine, give some consideration to the C-85 with the O-200 crank, pistons, connecting rods and carb. I used the STC from Aircraft Specialty Services and phone help from Don Swords. Everyone who has flown the Cub with this engine has had a WOW experience!
    Google Don Swords at Don's Dream Machines. He is a real gentleman and will take the time to make you smart.
    Don can also handle the STC.
    My "free" C-85 had toasted crank, cam, cylinders and carb. It was missing the mags. So it was just some extra bucks to go the STC route. In retrospect, if I had a better case, it could have been done cheaper. But the C-85 with O-200 parts -ROCKS!
    Pete
    rosiejerryrosie's Avatar
    Carlisle, PA
    Does the STC require modifying the vertical stabalizer?
    Cheers,
    Jerry
    NC22375
    65LA out of 07N Pennsylvania
    There are no airframe mods required by the STC. NOTE: the CAM is remains a C-85 CAM. This is really a good thing. The C-85 CAM in this mod produces an honest 97 HP. The O-200 is a 100 HP engine which is lucky to pull 90 HP. Also the C-85 CAM red lines at 2550 RPM whereas the O-200 CAM red lines at 2700 RPM.
    The fuel burn went from 4.00000 GPH with the A-65. No matter what we did, the fuel burn never varried. The modified C-85 gets 4.6 to 5.3 GPH. Cruise with the Sensenich 46 pitch prop is 80 mph at 2300 and 2400 takes me up to 85 - 90 depending on the load. Since max cruise is 90 mph, I keep the RPMs at 2350.
    This winter I plan on adding an 8 gal. aux wing tank - mostly, just to have a larger reserve after a 2 hour leg.
    Any more questions?
    Pete
    Carlisle, PA
    Nope. Thanks for the info...
    Cheers,
    Jerry
    NC22375
    May 2012
    Aircraft records restoration
    For starting a new logbook for the engine, reference the current revision of FAA Advisory Circular 43-9.
