Thread: BJ-1B Duster glider
    Feb 2012
    BJ-1B Duster glider
    I have plans for the Woodstock but am interested in also getting ahold of some Duster plans to check out/compare. Anyone know of the availability of some Duster plans out there? Anyone know of the differences in flight characteristics. Looks like the Duster actually has a little better of a glide ratio.
    Duster definitely has better performance than the woodstock. They are cool looking gliders!
    Mar 2012
    I have a set of Duster plans but am still dreaming of building one now that I am finally retired. Probably would not be legal to photograph and Email but if you ever get to the N.E. part of Indiana, I would be glad to show them to you. Also, you may not know, but a design option was for mounting an engine on a fixed pylon over the wings for self launch. Such an example was at Oshkosh perhaps in the 70's and is the way I would build it.
    really, i have never heard of a self launching duster. is that an option in the plans? I also have a set of plans and don't recall seeing it. besides all that extra weight requiring some decent beefing up of the wing structure (more weight) it would therefore really limit the allowable pilot weight and be quite literally a real drag.
    Mar 2012
    My set dated 8/20/71 shows only the optional fittings on sheet 5. I have more info about it somewhere in my 45 years of archives but haven't come across it lately. I found the photo of the one at Oshkosh. It is N11BJ and I don't remember much data from it. There have been a few changes to the plans and probably the most important was stiffening the vertical fin due to some having a flutter problem. I was going to attach the photo but discovered that the .pdf I saved it as won't work so will send it later.
    ah i see that now. very interesting
