Originally Posted by
rosiejerryrosie
It is a specially designed piece of rope that is used to hold a wing in place while it is being attached to an airplane It is first soaked in propwash and then attached to the wing and the fuselage. As it dries, it shrinks, pulling the wing close to the airframe so that the bolts can be easily attached. Don't let anyone tell you differently. It has absolutely nothing to do with the distance from the leading edge of the wing to the training edge of the wing measured directly through the wing. Nothing at all - cord is cord = rope or string, not a measurement....Look it up...
D:
Cord?? Nah! You may need a bigger, or better, reference.....
It's the measure of a pile of wood, that used to be attempts at hand carving a propeller,
but is now waiting for another job...
" Wood Fuel Operations Technician : w / Stove qualifications ".
The job though is seasonal, with more employment opportunities in the winter months.
Job description is the adequate heating of aircraft hangar, using any means possible,
tools include: waste paper baskets, old oil drums, trash cans, and a good source of ignition,
matches do very well in this endeavor. Applicant may need to supply own kindling.
Other items, to be supplied by employer.
Also when it's very fiber is broken down into nitrocellulose, and added to nitroglycerin,
and petrolatum that has been dissolved in acetone, dried, and extruded in cords, it is called
"Cordite", a smokeless explosive powder.
Excellent for starting overly hot "Flame Wars".
Would you use that to attach a wing to a fuselage ..... I think not....
