Results 1 to 10 of 11
Thread: Sealing plexiglass, stop-holes?
Threaded View
    bwilson4web's Avatar
    Huntsville, AL
    Hi,
    While removing some caulk, a 3/8" crack formed from the edge. I stop drilled it only to find a smaller, hair line crack formed from the stop-hole. A second stop hole and the part is stable. Fortunately this is just the wing tip cover for the navigation light so I only need a water-tight seal clear enough to pass light.
    Is there consensus on how to seal the stop-hole and/or water seal the crack?
    I did find an article using Acryfix to repair a canopy. But the article addresses canopy repair by laying up layers of UV cured, clear plastic. For a canopy that makes sense and it would work for the wing-tip cover.
    I've also seen references to using "Weld-On #4" and acetone dissolved plexiglass. Mostly looking for recommendations.
    I'm planning to use clear, GE silicon to replace the mold-growing, caulk.
    Bob Wilson
