Results 1 to 10 of 10
Thread: Aluminum Ribs
    prasmussen's Avatar
    Feb 2012
    2OH8
    Aluminum Ribs
    I'm designing a fabric covered wing with aluminum ribs. If the ribs are formed over a block, it seems like there should be a clever way to treat the bent-over edge so that it won't cut the fabric/lacing. Any ideas? I have one of those double-wheeled thing-a-ma-jigs but can't get it to bend the flange far enough back on itself.
    Quote Originally Posted by prasmussen View Post
    Factory airplanes with fabric covered aluminum ribs brake the edge of the rib flange somewhere around 10-20 degrees. This seems to prevent any unwanted interference. I get the same results as you with a cheap handheld flanging roller tool so I made some dies for a bead roller to do this. The results were first class.
    prasmussen's Avatar
    Feb 2012
    2OH8
    Hey Marty,
    This old Pexto is what I have. You milled dies to 20 degrees? Is there a possibility you have an image or sketch? Thanks for helping! P.Name:  Pexto.jpg
    Yes, I make what I need on my lathe. To brake the flanged edge of a rib you need small dia dies, like 3/4" or smaller, the bent down edge only needs to be 1/8" or so. Dies for you Pexto will have to be "stepped" down and probably extended beyond the axle to get the dia small enough. You need something similar to but not exactly like the this:
    Name:  flanging mandrel.jpg
    Where are you located?
    prasmussen's Avatar
    Feb 2012
    2OH8
    Wish I had a lathe. But it looks simple enough. Out of what material would you recommend I get it milled?
    Google says we are 4 hours drive or 5 hours flight in my old Champ apart. Just SW of Columbus, OH.
    Some cold rolled 1018 bars stock will work just fine.
    Is the Culver V also in Columbus?
    Keep me posted on your ribs.
    Marietta, GA
    The ribs on an Aeronca Champ (and the Chief too) don't have any sort of edge treatment at all other than being deburred. The flanges are essentially parallel with the fabric and are at a right angle to the web of the ribs.
    So, to answer the original poster, I'm not sure any edge treatment is necessary.
    prasmussen's Avatar
    Feb 2012
    2OH8
    It's true, I've never heard of a Champ wing skin splitting over a rib or rib stitching being cut by a sharp edge. Someone suggested gluing 1/2" tape to the rib edges before covering would prevent chafing. Then any movement would be fabric to fabric. How much does the wing lower surface actually push in? Suppose it depends on what system was used to tighten the fabric too.
