Chad, what kind of compass is that?
An electric Ritchie boat compass. Found it on eBay, worked great! I mounted the magnetometer for it in the tail, and it was dead-on accurate.
Chad Jensen
EAA #755575
Mike, you bet. RV-10s come with the vane type system as a standard part of the kit, although some RV-10 builders ditch it for an aftermarket AOA system. I chose to go with the standard stall warning system because A. I already had it, and B. I was too cheap to switch to AOA. You can order the parts from Van's if you're so inclined.
Last edited by Auburntsts; 02-17-2012 at 01:44 PM. Reason: Chad corrected me! See his post below.
PP ASEL - IA
RV-10 N728TT - Flying
EAA Lifetime Member
WAR DAMN EAGLE!
Not true...none of the two seat RV's come with a stall warning system of any kind.
Chad Jensen
EAA #755575
