Results 1 to 7 of 7
Thread: building my first aircraft
    Feb 2012
    Hi all, well first off I have had about 25 hours of flight time, but that was before Being deployed to Irac and the bottom falling out of the economy. Now I am still and always have been wanting to fly so now I'm going to try a different rout. What is an aircraft's wing cord?
    Anymouse's Avatar
    2A2
    http://bit.ly/z1Pcsb
    (Sorry couldn't resist!!)
    Sounds like you got a good start on the flight training. Try to continue if you can while building.
    rosiejerryrosie's Avatar
    Carlisle, PA
    It is a specially designed piece of rope that is used to hold a wing in place while it is being attached to an airplane It is first soaked in propwash and then attached to the wing and the fuselage. As it dries, it shrinks, pulling the wing close to the airframe so that the bolts can be easily attached. Don't let anyone tell you differently. It has absolutely nothing to do with the distance from the leading edge of the wing to the training edge of the wing measured directly through the wing. Nothing at all - cord is cord = rope or string, not a measurement....Look it up...
    D:
    Cheers,
    Jerry
    NC22375
    65LA out of 07N Pennsylvania
    Green Goggles's Avatar
    Oklahoma
    Quote Originally Posted by rosiejerryrosie View Post
    D:
    This is what I was always taught!
    Tongue Out
    D:
    Cord?? Nah! You may need a bigger, or better, reference.....
    It's the measure of a pile of wood,
    that used to be attempts at hand carving a propeller,
    but is now waiting for another job...
    " Wood Fuel Operations Technician : w / Stove qualifications ".
    The job though is seasonal, with more employment opportunities in the winter months.
    Job description is the adequate heating of aircraft hangar, using any means possible,
    tools include: waste paper baskets, old oil drums, trash cans, and a good source of ignition,
    matches do very well in this endeavor. Applicant m
    ay need to supply own kindling.
    Other items, to be supplied by employer.
    Also when it's very fiber is broken down into nitrocellulose, and added to nitroglycerin,
    and petrolatum that has been dissolved in acetone, dried, and extruded in cords, it is called
    "Cordite", a smokeless explosive powder.
    Excellent for starting overly hot "Flame Wars".
    Would you use that to attach a wing to a fuselage
    ..... I think not....
    Carlisle, PA
    The original post asked about a wing cord. So the answer must have something to do with a wing. And anyone knows that 'Cordite' refers, primarly, to a female cord... or is that Cordette? I'm confused.....
    Cheers,
    Jerry
    NC22375
    Welcome to your next addiction! Rosie gave the correct answer above, btw...
    I thought it was the things that fastened the airplane to the ground. Bungees from the wings to the little metal loops set into the concrete on the ramp are much easier than ropes to connect - and they come in an assortment of colors.
