Results 1 to 8 of 8
Thread: RV-1 Plans?
    prasmussen's Avatar
    Feb 2012
    2OH8
    RV-1 Plans?
    Early in the development of the RV line, there was a modified Stitts Playboy with a cantilever, all aluminum wing. I've seen pictures and know that somewhere there are plans. Vans aircraft has confirmed a set or two but, understandably, won't supply them for liability reasons. Can you help? I have a Playboy project on the gear and understand the redesigned wing will make it fly a lot better. Thanks.
    I guess anything would be an improvement to the Playboy's handling characturistics...that's one twitchy beast.
    Have you talked to the RV1.org guys?
    Eric Witherspoon's Avatar
    Tucson, AZ
    That's rv-1.org
    Lots of info there, though I wouldn't be surprised if no plans exist.
    http://www.spoonworld.com
    Chad Jensen's Avatar
    Oshkosh, WI
    The Friends of the RV-1 folks do have a set of wing plans, but they are not available. Pics are here though...
    https://picasaweb.google.com/1147263...tructionPhotos
    Chad Jensen
    EAA #755575
    prasmussen's Avatar
    Feb 2012
    2OH8
    Hi Ron,
    Is that twitchy as in Pitts or unstable, ground loop twitchy? Before I started, I was told the Playboy was a pilot's airplane so I expect to have to pay attention. Hope I'm not building an airplane I can't fly. Thanks for your comment. P.
    prasmussen's Avatar
    Feb 2012
    2OH8
    Thanks Chad. I had no idea a group was restoring and going to tour Van's RV-1 down the east coast. Lots of great pictures.
    Very unstable at low speeds from a friend who used to have one. Takeoffs required a lot of care. I guess if you want things to be acrobatic you got to give some of that up but it seemed to be excessive.
    Jim Hann's Avatar
    My advice, keep asking around. You never know what might turn up in somebody's hangar!
    Jim Hann
    EAA 276294 Lifetime
    Vintage 722607
    www.mykitlog.com/LinerDrivr
    Fly Baby/Hevle Classic Tandem
