Results 1 to 8 of 8
Thread: Rotax 503 Manual?
    Petersburg, In
    Rotax 503 Manual?
    I there some where to get a manual that tells in detail how to disassemble and assemble a rotax 503?
    Skagit Valley, WA
    Down load it from the Rotax website.
    Tucson, AZ
    Rotax 503 Maint Manual
    Download the Maintenance Manual from this link.
    http://www.rotax-aircraft-engines.co...opdefault.aspx
    You can also download the Installation Manual, Operators Manual, etc. on the same website.
    A.J.
    Petersburg, In
    Thank you for your response, but I have looked at all of these sites at Rotax and they are not giving enough detail about steps of disassemble assemble, what tools to use, measurements and such. I may have to send it to a certified repaired center, but I like doing mechanical work myself as I have on auto and heavy equipment most of my life. Thanks again for all responses. Gary
    rotax 503 rebuild
    Contact California Power Systems and order their catalog. It contains a section called "The Proper Care and Feeding of The Rotax Motor." Phone # 1-800-247-9653 or website www.800-airwolf.com.
    Petersburg, In
    Thank you I just ordered the catalog after reading your reply,
    Fort Frances, Ontario
    Video for Rotax 503 rebuild
    You can get a 503 rebuild video here http://www.ultralightnews.ca/videos/.
    I can't say if it gives you torque specs, as I haven't actually seen it, but might be helpful to see how its done.
    S9pilot
    Petersburg, In
    Thank you, it looks like it might be some help, and worth ordering it's not that expensive.
