Results 1 to 10 of 22
Thread: Successful Project Completion: Bearhawk vs RV-7
    I'm trying to decide between QB Bearhawk and QB RV-7. Any thoughts on completion stats between the two aircraft? I'm leaning toward the Bearhawk but am concerned as it looks like a lot of kits have been started but not finished.
    Chad Jensen's Avatar
    Oshkosh, WI
    There are a lot of RV kits that get started and not finished as well...the sample is much larger tho. Do the numbers on Bearhawk completions include plans built? Can't do that with an RV, so I wonder if the comparison is apples to apples.
    Chad Jensen
    EAA #755575
    Spencer_Gould's Avatar
    South Florida
    From what I've seen since my envolvment with homebuilts since 93' is the RV's are the best you can get for project completion and the set the bench mark in a solid build process and completeness. The bigger issue is metal construction right for you, although there is learning in any new project make sure this is the construction medimum that best fits your skill sets, I'm a composites guy but to each their ownSpencer
    Thanks for the inputs. I love both airplanes, but can only do one. The Bearhawk seems to make more sense for my mission preference. In reviewing some of the websites, it just looks to me like a lot of guys have had their QB kits for a number of years with not a high completion percentage. I don't know if that is an accurate perception though. I was just curious if anyone has heard of any problems with the kit or plans that may be hindering completion.
    South Florida
    What kind of workshop setup do you have for the project? Have you done any sheet metal work before? I've found time and time again the biggest drivers for getting the airplane done often have nothing to do with the plane type it's self, but alot to do with a usuable every day work shop, a rutene schedule where you can spend a few hours a day every day an proficient fabrication skills in a particular construction method.Spencer
    My preparation is coming along. I'm converting my garage to a workshop, finished the insulation and wiring with 110/220, paneling the walls and installed the airconditioner so I can work in the Texas heat. Also attending an EAA RV-7 workshop in August. I think even if I decide to go with the Bearhawk the RV-7 workshop will be time well spent since there is still riveting to be done on the Bearhawk. Will be attending a fabric covering workshop when one becomes available clsoe to me.
