Results 11 to 20 of 21
Thread: Cutting rubber blocks
    I wonder how cold you would have to get the rubber to cut it on a lathe?
    I've cut fairly hard rubber on a lathe, high speed and knive edge cutter.
    I used a 1.5" hole saw to cut 1" rubber on my drill press. It worked OK at room temp.
    Norman Langlois's Avatar
    Northwood ,N.H. USA
    Modifying a hole saw will work. be sure to sharpen only the inside beveling towards the outside this will ensure the cut goes straighter. I have made similar cutters for making holes in such rubber, for bolts that way. removing the plug will be your only worry after that .no need to use the centering drill ether. [As per your plan with the plate] your only failing will be the adheasive to the plate.try something at the corners like drive points. an alternative would be to simply press your cutter through with a hydraulic press.lube and sharp will make it happen.
    regards
    Wichita, KS
    I have used my mill with a ½” end mill installed and had reasonable results. I believe I had the spindle speed as high as the mill would turn. It wasn’t like you cut it with a razor blade but the proper shape was made. This was done with the rubber at room temperature. The 1" thick rubber was screwed to a block of wood and bolted to a rotary table. If I did it again I would try gluing the rubber to an aluminum plate with 1300L adhesive and cleaning the adhesive off with MEK after the part was finished. I finish shaped the rubber on my lathe using a die grinder with a 2” sanding disc installed. The rubber I used was pretty soft so I didn’t feel it would cut well on the lathe. I attached a picture of the finished tire on my boys stroller project. Good luck.
    Oak Harbor Wa
    Step 1, make a 6" circle from scrap Oak, mount it in the lathe, and turn surface flat and sand smooth, then apply common rubber cement from local hardware and allow to dry.
    Step 2, Clean the rubber block and apply contact cement and allow to dry.
    Step 3, join the rubber block and wooden circle being sure it really sticks.
    Step 4, manufacture holder for a Dremil tool motor, that will allow it to be held by the carriage of the lathe, and mount to the carriage cross feed.
    Step 5, Run the Lathe at a very slow speed, and feed the dremil tool into the turning rubber block using a 3/8 square ended router bit. This will cut the outer circumference.
    Step 5, adjust the carriage to cut center hole, and proceed to cut away the center, and remove the wooden block from the lathe
    Step 6, remove the rubber part from the wooden block and place the rubber part back into the lathe and using a 1/2" sander bit in the dremil adjust center hole unit it fits shaft.
    Place the shaft in the lathe and adjust the outer circumference to fit the cylinder in the same manner.
    And that is how you make a Fairchild strut seal.
    All the knives didn't work but the dremil cut it with no sweat.
    cool...
    Valentine NE
    I'm impressed with the results acheived with the lathe and Dremel. Can anyone provide sources for rubber stock?
    Matt Gonitzke's Avatar
    Wichita, KS
    Very cool...
    Oak Harbor Wa
    Quote Originally Posted by tmadison View Post
    google jewelers supplies or http://www.fusionbeads.com/shop/product/31925/ they are ll over the net .
    Christopher Ingram's Avatar
    Feb 2012
    Glendive, MT
    Whenever I have needed to put holes in rubber for body mounts etc. I have used a piece of pipe of the correct I.D, beveled the edge then just heated it up with my torch and made the hole. Works like a champ and leaves a better/smother edge than cutting.
    Keep it simple out there,
    Chris
