Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Cutting rubber blocks
    Oak Harbor Wa
    Any one have suggestions on how to cut a 1" thick piece of rubber block and get a smooth surface?
    The material is black rubber 4" square and 1" inch thick, I need to make a 3.5" round pad.
    got any tricks?
    You can try freezing the rubber to make it hard so it cuts like wood.
    It's been decades since I tried this, and I can't remember if it worked or not.
    Mike Switzer's Avatar
    Central Illinois
    I'm wondering if a Greenlee hole punch would do it (if you dont mind a small hole in the center)
    Oak Harbor Wa
    I don't think my freezer will get that cold, it would take a dose of N2 or something.
    The freezer should be about 0 degrees.
    I have used liquid propane at -44 degrees. To get a cup of liquid propane, hold a propane bottle upside down and let some out. About half will evaporate and then the remaining liquid will be -44.
    Do it outside, of course, and wear gloves.
    Oak Harbor Wa
    I have been contemplating using a 3.5" hole saw modified by removing the teeth and grinding a knife edge on it. Gluing the rubber block to a board, and clamping that to the drill press table, and running the drill press as slow as it will go. adding lubrication for the blade.
    the propane sounds a little scary.
    I think they sell dry ice at Safeway.
    Oak Harbor Wa
    I wonder how cold you would have to get the rubber to cut it on a lathe?
    Minnetonka MN
    Dry Ice & a lathe - I think that's the best idea. Silicon grease will help any cutter or knife slide thru the rubber. It depends a lot on the physical properties of the rubber block though.
    Oak Harbor Wa
    Quote Originally Posted by nrpetersen View Post
    The material will be here today, I have a steel plate that has been turned round at about 5' I think I'll try gluing the rubber to that and try cutting the rubber on my lathe with the modified hole saw in the tail stock. That way I won't worry about holding the rubber, or getting enough pressure on saw, or frost bite
