Thread: Can You Help Identify This Wing Spar
    Question Can You Help Identify This Wing Spar
    I have some parts for a wing spar given to me by a friend. He didn't know what they were for.
    This is a picture of the top and bottom center section caps. I don't have a web.
    They are made from aluminum T section.
    Name:  pics 06-29-11 011.JPG
Size:  85.1 KB Name:  scan0001.jpg
Size:  67.5 KB The dihedral is about 4 degrees.
    I also have two more caps that are 154" each. I assume they are to be used to make the spar for the outer wing panels. That gives about a 28" wing span, if my assumptions are right.
    There is also a box tube about the same length.
    Does anyone know what they are for?
    Can anyone use this spar? I don't need it.
