Results 1 to 10 of 12
Thread: What is the weight for VH ?
    Dec 2011
    VH is defined as the maximum speed in level flight with the maximum continuous power at sea level. What is the weight of the aircraft for VH? Is it that of an empty aircraft with a skinny pilot and minimal fuel ? or MTOW(Maximum Takeoff Weight) ? or any weight between these two extremes?
    steveinindy's Avatar
    Indiana
    The standard (if there is one) should be listed in the FAR. However, I believe (with the possible exception of the LSAs) it may be left up to the "manufacturer" to decide it as when I went looking quickly, I saw no reference to weights. However, I came across this one a site about the Sonex aircraft:
    specifying that speed at Vh must be measured under the following conditions: speed in level flight with maximum continuous power (Vh) of not more than 120 kts (138 mph) CAS (Calibrated Air Speed) under standard atmospheric conditions at sea level.
    SOURCE: http://www.sonexaircraft.com/ads/rx/index.html
    There may not be a weight stipulation. Either way, it should be tested in all conceivable and rational configurations during initial flight testing (and during design calculations for the purposes of determining structural loads) Are you designing your own aircraft or building something from plans or a kit? Unless you're doing a clean sheet design or drastically altering a design, you probably don't have too much to worry about it.
    The only time (other than regarding structural concerns) that Vh has any real concern is when you're talking about an LSA. Other than that, it's just bragging rights.
    I would assume it would mean at any permissible loading. If we're talking the LSA limits, there likely isn't going to be that much of a difference, the usable loads are usually pretty skimpy.
    Indiana
    That's the big problem (well besides the slow part) with the LSA concept: you have a large meal and you're over gross. "Sorry Bob, looks like you're going to have to walk home. If there is a headwind above five knots you'll probably beat me there." LOL
    Check 6's Avatar
    Here is the definition per ASTM 2245-10c (LSA certification)
    3.2.33
    VH—maximum speed in level flight with maximum continuous power (corrected for sea level standard conditions)
    Quote Originally Posted by Check 6 View Post
    That's exactly the same one from 14 CFR 1.1.
    It doesn't answer the question though.
    Check 6's Avatar
    Tough crowd. Maximum gross weight (there is a tolerance).
    Check 6's Avatar
    For clarification, the maximum gross weight is ultimately set by the manufacturer, but not to exceed the 1320/1430# per the FAA. The weight of course could be less.
    Dec 2011
    I asked around. The answer from two DERs was the lightest possible weight. Not the maximum gross weight. I am designing from a clean sheet. Some cautions here include possible power plant upgrade in the future and speed estimation errors, so add a few knots to give some margin. Vh is a speed used for all aircraft, not just LSA.
    Check 6's Avatar
    I am addressing S-LSA. It is maximum gross weight. I confirmed this with a member of the ASTM S-LSA certification committee, plus it is addressed in 2245-10c. A minimum weight would be an open ended number, e.g. the certification would depend on the weight of the pilot and how much fuel was carried which is not very exact. Maximum gross weight is more exact.
