Thread: airbike
    airbike
    anyone know where I can get technical information regarding an original airbike?
    I recently joined the local chapter of our EAA and one of the projects is redoing an airbike ground up so Im just looking to build the library up a little with anything I can find on them.
    rosiejerryrosie's Avatar
    Carlisle, PA
    Try these guys:
    www.­jdtmini-­max.­com
    Cheers,
    Jerry
    NC22375
    65LA out of 07N Pennsylvania
    There is a guy that occasionally sells original Airbike and Tandem Airbike plans on Barnstormers. Plus he has a "new and improved" version.
    http://jordanlakeaero.com/
    AirBike Information
    Kurt,
    I have some of the original AirBike sales and brochure information, I can copy and e-mail it to you if that would help, also, contact http://jordanlakeaero.com/ for more information. You could also go to my website http://www.airbikeace.org/ to see how much fun can be had with an AirBike. It is possible I spoke with you previously on the Buzzards Board. Good luck on your EAA group project!
    Paul Fiebich
    a.k.a. AirBike Ace
    West Glacier, Montana
    Airbike Rudder
    Be sure you use the bigger rudder. I had an airbike with orignal rudder controle was marginal at most when at a high rate of climb. I would give full left rudder plane would still veer to right.
