Thread: Daimler Benz 605 Help?
    Happy Daimler Benz 605 Help?
    Not sure where to post this, sorry ahead of time if its in the wrong spot.
    I'm looking for some help in finding some technical drawings, or very detailed Engineering drawings of the DB 605 engine block
    Ive been on this quest for a little while now and have found nothing but simple drawings that give some ideas but nothing that shows measurements and are out of scale or skewed
    the ultimate goal of this is to make a 50% scale replica of the 605 engine for a "secret" project.
    Justin, Texas
    William: Might see if you can get in touch with Wojceich Nieweglowski over at http://luftwaffelovers.blogspot.com/p/3d-modelind.html. He's done quite a bit of 3d modeling of the 605. I did run across a reference that said that the 605 was basically a bored out 601, with some other changes. Might also check and see if stuff is still available from https://www-luftfahrt--archiv--hafne...n&_x_tr_pto=sc It also appears that the archives is selling via ebay as well. I did find some references to a shop that was in the early process of casting new blocks, but the primary contact is not on those boards anymore and his website is gone. There has also been references to Vintage V-12's having quite a bit of documentation on the 605. There is another seller on ebay, ebook1959, that has a dvd with a bunch of DB605 stuff.
    Craig! awesome references thank you very much!
