This was the 21st time I flew my airplane into AirVenture Oshkosh.
Went a day early (Saturday) because I was forecasting IFR Sunday morning and expected that to saturate traffic Sunday afternoon. My forecasting was off a little as I had forecast 11 AM when VFR traffic would start arriving and it was more like 10:30 when arrival started in mass.
Saturday I had weather as I approached Chicago area. I had diverted south and west of my planned route. Turbulence was such that my A-20 headset left my right ear and was only on part of my left ear. G-meter recorded +2.5 and -1.5. I ended up 115 NM off course because of weather. I was 35 NM west of my intended fuel stop but knew I could get fuel at C73. I was avoiding C73 as I knew there was a large group there practicing formation and would be doing a mass arrival.
Departure for the last one hour flight into OSH was about as expected. It felt that I would be arriving after the Cessna mass arrivals were over. I was wrong. The Cessnas were using runway 36L and ATC was using one mile spacing for arrivals as they only had one runway that the Cessnas were not using. No issue there as I could not see any aircraft in front of me but ADS-B in showed one 2 or 3 miles ahead. As I approached FISK, I head ATC direct an aircraft right turn to runway 18. A little while later, I also was directed to turn right to runway 18. As I got closer, runway 18L was where they wanted me. Never saw the aircraft in front of me but it did a go around. I put the aircraft right where ATC wanted it so I think I was the first aircraft to land on 18L after the Cessna mass arrival. Parking and tiedown was as usual.
Having flown into OSH AirVenture before, I knew the routine. I do NOT like the security checking bags every time I come back on the airport. I flew in and could have brought anything including an item they do not want. The security check line was longer with waits to get in much longer than any year in the past. No were near enough people to check incoming bags. I was using the gate from the bus stop that is due east. I departed Thursday as I felt it had the least Wx issues for me heading home. I felt like I spent 5-minutes in line getting my suitcase, backpack, and water cooler inspected before I could get to my airplane.
Flying my airplane into AirVenture then needing to get my belongs / bags check to depart is getting to be an issue with me. This may be my last trip to AirVenture as I do not like this security search.
Trip home again has Wx to deal with. Lots of airplane departing Thursday. After 50-minutes of taxi and holding, I was till not on the runway. My airplane spend the first 16-years in the Southwest where high temperatures are normal. My airplane was built to be able to operate in high heat with high temperatures. After 50-minutes, I was at 220 F oil temperature. I know at this temperature that I can have missing due to vapor lock on my takeoff roll. I did have a little engine stumble on my takeoff roll but I was able to get to full RPM (constant speed prop) and smooth running engine as I accelerate on my takeoff roll. No issue to my first fuel stop. Was suppose to met friends that taxied out in front of me there but they were already refueled and taking off 1/2 hour before I would arrive. After fuel stop, I was not able to go direct on course due to Wx. I had to fly South for a while before turning toward Atlanta. Watching ADS-B Wx, I knew there were strong radar returns (Reds, Pink, and Orange) to avoid. Started out flying under but do not like flying at 2,000 MSL under clouds. The broken layer had big enough holes that I could go up and come back down so I decided to go up and take a look. Much nicer on top. Had holes large enough that I could get back down. I could see sunlight on clouds ahead and to the east. Turned more direct toward home with the idea I could turn back toward Atlanta if needed. As I approached home, I figure I would stop and fill up as I do not have fuel at my home base. Arrived home after 6.3 hobbs hours. This should have been about a 4.5-hour flight.
I am more out of shape now that I am older. Only walked 19,600 steps on Monday. Tuesday was down to 12,100 and I was tired as I did not get enough rest Monday night. Guess I need to admit that I am part of the Medicare crowd and should not be pussing myself.
I will review this post next year to determine if I will fly my airplane to AirVenture again. I may be IFR rated but would not fly IFR in the weather that I had on the way to and from OSH. I would rather drive 16-hours over two days than fly in turbulence. Searching bags of people that flew into OSH when they come back on the field is another issue that will keep me away.
Maybe I am the only person that does NOT want the bags that will be in their personal aircraft inspected by EAA security people. Having my bags searched is enough to keep me from flying my aircraft back to AirVenture in the future.
