Quote Originally Posted by cub builder View Post
Rereading your reply, you have it firing 90° off. If it was me, I would make sure the mags are timed to #1 cyl at TDC on the compression stroke, then simply follow your plug wires and put them on in firing order. It's an easy fix you should be able to do in pretty short order.
Good luck with it.
-Cub Builder
Just want to make sure I understand. You ARE saying to remove the mags and retime, correct? Or are you saying simply reroute the wires to move them 90 off? All of my plug wire caps are stamped with T1, B1, etc so it would be simple to move cyl #2 wires to plugs 1, etc. What a nightmare in future repairs though!!
