Question from a total Newbie
So I've decided I'm going ahead with Solidworks but am not sure what I need to get. What I need for results is to be able to design and then test the design for movement/clearances/motion. Then finally to cut certain needed parts on my CNC plasma table. The plasma cutter uses Fusion 360 so I would need to output a compatible file. I appreciate any direction I can get.
