Marcel Jurca MJ-2 Tempete Aircraft Project for sale
Attention Home builders, aircraft restorers or lovers of Marcel Jurca Aircraft.https://www.marcel-jurca.com/index.php/en-us/
Marcel Jurca MJ-2 Tempete ProjectCF-REX SERIAL#53Built from plans designed by Marcel Jurca, the Tempete is a Single seater all wood aircraft, aerobatic capable, Unique straight longeron wing, identical ribs. Fixed landing gear. Integral bubble canopy.
CF-REX was built and first flown in 1962 by J. Broeders in Chatham, Ontario. It flew until 1969 and with 298 hours on the air-frame when it met with an accident while on takeoff.It flew with a Continental A65. (Includes Continental and Lycoming 0235 engine mounts)
The project is looking for a new owner to complete the restoration.Most of the work has been completed with only a small repair needed to the wing, then re-assemble, add powerplant, instruments and re-cover.
Full set of plans are included with everything you see here.
Landing gear features: Clevland 500x5 wheels, disc brakes and calipers on the main.
A great project at an affordable price! $1500
Aircraft is located at CYSH, Smith Falls, Ontario, Canada
PROJECT HAS BEEN SOLD!
THANKS
Mark Kinnin
