Spraying Preservation Oil into Cylinders
Following the lycoming Service bulletin for engine preservation, I'll be using Aeroshell 2XN mixed with Aeroshell 100 oil.
It says to spray atomized preservation oil into the cylinders using an airless spray gun such as "Gunjet Model 24A-8395" which I can't find anywhere.
I'm wondering what other people are using to spray preservation oil into their cylinders prior to storage?
An inexpensive hand pump sprayer such as something used for chemical spraying would be ideal if there is something out there that can atomize the high viscosity of aeroshell 2XN mixed with Aeroshell 100.
Thanks for the help!
