Good question and better answers for sure. I guess the problem is as Ron eluded to is that home built has become assembly of kits and get it flying. When I started building my plans built biplane project, the common advise was "don't deviate from the plans" and "don't deviate from the plans". Luckily I had an engineer that loved to see my ideas. He never discouraged me and always explained the mechanics behind the device. He also never approved anything I designed. He had a dual degree; Engineering and Law.
When people ask when I expect to finish, I always tell them "in the spring". It may not be this spring or the next spring, but some spring the project will be flying. Next door to me a couple of guys are hoping to finish an RV6 in about 800 hours. It's definitely going to look like a run of the mill RV6. For me it takes about that amount of time to come up and implement an idea. I changed the wing bow purely for aesthetics and added a hand hold for nostalgic reasons. Don't ask me how many hand holds I made to get the feel of what size it should be to fit someones hand comfortably. And of course, look good.
It's easy to order a stick grip with a PTT from AircraftSpruce. I ordered a variety of PTT buttons from Amazon and milled a stick grip from aluminum. Idea to completion was a couple of months. It's not in the plans but works for me and was fun to build.
So if you're looking for articles about experimentals that aren't kit built or professionally done, they are far and few between simply because experimenting takes time.
